since the onset of the cold weather when i go out in the morning to start the motor its almost like theres no fuel at the injectors, eg it cranks and cranks then picks up on 1, 2, 3 and then all 4 cylinders, the glow plugs are working fine, theres no fuel leak from the pump or any of the injectors and i've fitted a non return valve between the filterhead and the tank as i thought it may be syphoning back that way, could a leaky injector let the fuel drain back to the tank on the return line and therefore the system basically has to bleed itself each time i try to start it??
yet ANOTHER starting problem
first thing i checked and yes they are all working correct, you'll be able to pump the pump on the filterhead once its been running anyway as when its running it creates a vacuum between the injector pump and filterhead so you will lose any pressure you've created!Originally posted by TonyN View Posthave you checked the glowplugs?
