There is no pump in the tank. First thing to check in any diesel that wont start is the stop solenoid. Its in the main fuel pump.
Put you hand on the side of the pump and get someone to turn the ignition on but not turn the engine over. You will feel a strong click from the pump if its working ok, you will probably hear it as well.
You may be getting fuel from the injectors but if its not opening ok there will not be enough to lift the spring in the injector.
If its not clicking ok check all you wiring connections in paticular the large grey connector cliped to the side of the pump and the 2 earth wires near the back of the inlet manifold, brown wire as fare as i remember.
If it is clicking ok you could try a bit of easy start up the pipe to the throttle body but only use a very little bit to see if it fires or it might run away on you, brake cleaner works as well if you dont have any easy start.
If thats not it check the vavle timing there isnt much else that will stop it firing .
