Hi Guys.
Was posting an Item but I seem to have got timed out so my original posting may or may not appear somewhwere???.
Similar to Hawkwind my heater has stopped working.
All valves/mechanicals/fans work ok.
Water in pipes ether side of matrix are reasonably warm.
Temp guage reads contant at just below half way.
There is no water in oil.
Threre is rusty water in expansion tank which is dry every 3 days or so.
There does not appear to be any leaks in the rad or water system.
When removing the pressure cap, water is full to top.
I have replaced the stat.
There is no sign of water dripping onto floor. Inside or out.
When I switch off the engine I can hear a hissing sound just left of centre of engine but cant see any water leaking or rusty stains. The hissing is probably constant but cant be heard with engine running.
The rear heater is also blowing cold.
Can live with cold but worried I may have major water sytem failure while stuck on the M60/61 junction in the morning. I have been temporary unemployed and cant afford a major mechanical disaster. Have a temp job for five week for which I am travelling 60-70 mile per day so need to keep surf running.
Any ideas anyone.
Mark
Any ideas anyone.
Mark
