Originally posted by Antob
View Post
Anti Roll links
mine were the same with the poly bushes. rough trax supplied mine as well.
i turned some spacer washers in the lathe but normal plate washers will do the same job. if i remember stainless plate washers are easily available 3mm thick so you would only need 2 each side instead of a handful of the thin tin ones.
