Those little pipes are a nightmare as they are normally the cause but virtually the lasyt thing to look for.Glad you got it sorted tho
airbox - turbo light
Yep. FYI. This sensor really has nothing to do with the turbo except for sensing the pressure from it. The turbo will work regardless, as it's purely a mechanical turbine. The sensor tells the ECU when to add more fuel. This is where the extra power comes in. Without the sensor connected the engine just runs leaner.Originally posted by BAV1 View Postso suppect if i had found this with then new cone on all would have worked
Nev
that would explain the lack of power alright i do have some other question regarding my list of mods but will leave them for now
oh what the hell will ask one was thining of extending diff breathers etc so i can go paddling and may add a snorkel when doing the intercooler
whats involved in getting everything that needs to be above the wheel arches
cheers
luv my truck but without you guys would probably given up when the first dead does anyone remeber the pimped out one that had been lowered all i can say in my defence was that i had a vision
cheers again
The diff breathers are easy to do.If you got a body lift the front one will be easier.You can get the breather unions from Toyota and the pipe from B&Q or somewhere.Then run both up top the engine bay and put one of those little petrol filters on the end to stop any crap getting sucked inhttps://www.facebook.com/groups/henpals/
here's a link to when i did mine.
http://www.hiluxsurf.co.uk/forums/sh...diff+breathershttps://www.facebook.com/groups/henpals/
http://toyotasurf.asn.au/techsite/performance.htm will be helpful
front mount intercooler http://toyotasurf.asn.au/techsite/intercoolingf.htm
In regard to ..... well the intercooler anyway!The sh$t gets deeper ...but still swimming
I thought that sensor (the one in the pipe by the filter) was ambient air temp rather than flow. I suppose if it is heated, then it could sense flow by means of wind chill, but as there's only two wires I dont see how that could happen.Cutting steps in the roof of the world
Yep, it's a temperature sensor, not air flow.Originally posted by Apache View PostI thought that sensor (the one in the pipe by the filter) was ambient air temp rather than flow. I suppose if it is heated, then it could sense flow by means of wind chill, but as there's only two wires I dont see how that could happen.
Nev
lol ight on dash and fan under the egine spins up but just warm air i assume it just needs a regas but after reading a couple of posts seems there MAY be an issue as to what gas has been used in the past dont know when it was last working
1. any way of telling what gas is being used
2. any easy way of telling if i can get away with an aircon can from halfords
3. any body had theres done recently near manchester if so where and how much
(edit) read some more postsand seems the engine revs should increase they dont any ideas
