My son just reported a rattle which is clearly fan hitting fan shroud.........guess what.........quite a few fan blades are well damaged !!!!
However it is not merely as simple as securing using the seemingly appropriate holes.Holes on fan shroud don't seem to line up with all the rad holes so it is only held on with 2 bolts.
I suppose it might have been fitted from a different vehicle and we have only noticed since cam belts were changed.
So............we are thinking of just taking the shroud off to avoid any further fan blade damage. The shroud would appear to be for protection only although I suppose it may assist in airflow direction at a push.
Can anyone think of a technical reason for not just taking it off???
Ta
DS
Ta
DS
