Hi there.
Am in need of your experienced expertise please.
The truck developed a most disconcerting problem 2 days ago.
Going up a say 6 deg or so gradient, stuck behind a road sweeper for 300yrds roughly at a crawl. Then proceeded to overtake the sweeper & within 20secs, which I can only describe as when a petrol engine looses spark in one or more cylinders, the engine was runnin' real lumpy with vibration & lost alot of power.
No smoke, engine temp ok. Got to top of hill & pulled over to take a peek.
Oil level ok, couldn't see at 1st glance any major sign of oil blowing anywhere; vacuum lines that had slipped off.
Re-started truck & after min or 2 seemed to be ok. Taking it home from work, vibration & power loss returning now & again. Now, the vibration is bad enough for it to be put 'out of service' until I can either get it to someone down in the East Devon area who knows these baby's as I don't have access to a ramp, or try & tackle it meself with ur help.
Am going to get under it now & take a peek & see what I can see.
New noises it has developed are:
When reversing & then selecting Drive, there's a clunk noise (one clunk only!) coming from mid to rear section.
When cruising & gently come off the gas pedal, get a high-pitched whining noise from front end whivh goes after you accelerate again.
Lots of white/blue/grey smoke (yes I would say it looks like all 3 together
) when going uphill (almost, but not quite a James Bond), fine on the flat.
Last oil change 2k's ago-new filter/replaced fuel filter & air filter (which incidently I checked for any kinda blockage)
Sorry to write such a long winded post, but I guess too much information is the best way forward...maybe
Will report back any findings asap, but in the meantime if your acute truck senses can offer up starting points, that would be soo appreciated
- thanks guys (& dolls)
