Hi All
Attempting to remove fuel pump on 2.4 LN130 to change leaky seals
Made good headway and have removed Timing belt cover, pump drive pulley, fuel and electrical lines and two front retaining nuts (so it should be ready to come out! )
Now the pump will rotate a bit, but won't move backwards clear of casing
found what appears to be a bracket preventing rearward movement
Can't see how to get this bit off as nuts appear to be under the outlet fittings on rear of pump
any ideas?...we've been at this for over 10 hours and it is getting trying with every new obstacle
no instructions/manuals seem to mention this bracket....
Help!!!!!!
Ben the Brave
Help!!!!!!
Ben the Brave
