you have to take the screw/bolts from the lack face and take the door card off and i think theres a couple more bolts to be taken out from inside.you will need to remove the plastic cover completely to get the motor out and unclip any of the rods thats attatched to the servo.
I think thats all i did when i took the c/l servos out the breakers
Well I swapped it out this afternoon it now works as it should,
so it was a part rather than a wiring fault,
as suggested on other queries on locking here.
(BUT) ...
can't see how the button that pokes from interior door top
fits into the mechanism, not that its vital in any way
as door unlocks on a key fob,
but for the life of me I couldn't see how it pokes down through that plastic sleeve on the (interior side of the glass)
to then hook up somewhere
so its on the bench waiting for further instruction on replacement
I'll have a look on one of the doors i got here and get back to you but i think it should push up from inside then the rod connects to a small plastic clip on the lock mechanism
Your right of course, and its my own fault not noting which clip it came off, but examining the mechanism on the bench I could only see on latch that seemed to work to unlock the door, that being the interior pull handle, nothing else appeared to click up or down when that was operated
actually Richard, reading this as I type it looks like I'm trying to hook up something totally wrong anyway like a dipstick.
Can you instead identify which one that button should go into on the mechanim
and its path down the door in relation to the glass
(as I did notice at least) the sleeve is cranked slightly as if to go around something
Hmmm might be as well Richard,
Nev thanks but they don't show up too well under magnification TBH
I had a look again this morning at the original lock and my button
here on the bench, but I think I'd like to confirm just exactly where it clips on at some point if its not to much bother
