Originally posted by RodLeach
View Post
Head Gone ?????
when my head went the only indication that it had gone was the temp would rise only over 80. when i got the truck back home there was no water in the oil no white smoke nothing to say that the heade had gone. then she started running rough on start up only so got a block test kit, 3 trys later and it showed it was fcuked
Damn, I reeeeeeeaaaaaallllly dont want the hassle if mines toast...Originally posted by sledge View Postwhen my head went the only indication that it had gone was the temp would rise only over 80. when i got the truck back home there was no water in the oil no white smoke nothing to say that the heade had gone. then she started running rough on start up only so got a block test kit, 3 trys later and it showed it was fcuked
But i'd have been living with it f**ked for whats probably 2 years. It's never been any trouble engine wise.
i get loads of white smoke on start ups, and its rough as old boots but only when the engine is cold as well.Dont forget rod, there can be a lot of moisture in the exhaust pipe itself.passing hot gases over them will cause them to steam,i think your fine dude.
roy, it does sound like the head is done. get a sniffer test done mate and go from there.Non intercooled nothing.
Originally posted by gwh200 View Posti get loads of white smoke on start ups, and its rough as old boots but only when the engine is cold as well.Dont forget rod, there can be a lot of moisture in the exhaust pipe itself.passing hot gases over them will cause them to steam, i think your fine dude.
Thats what i wanna hear!!
So all is not bad news on this fine day
, drove up to see Toby today 260 kilometres round trim with out a problem, no smoke at all, whilst talking to Toby about his latest off road trip he showed me some pictures and behind his surf was another surf with plooms of white smoke coming out of the exhaust, just been through a deep puddle and filled the air intake with water
Then hey presto it then all clicked into place, my radiator has sprung a leak and sprayed a fine get of steam onto the power steering pulley, where it condenses and is then thrown up into the air intake, hence when I am stopped, more water would build up without being burnt by the engine, creating a ploom of white smoke.
Just the oil pressure to sort out now, ill change the oil and filter tomorrow and go from there, I do know that I have a oil leak which is dripping down by the bell housing, but I cant see where it is coming from, I cant see how this would effect the pressure so, will have to look elsewhere.
Thanks for all the quick responses and the reassurances that it’s not the head gone.
Had to change my underwear four times yesterday.
Roy
When ya stop having fun, Ya start getting old
