On starting the truck this morning, I usually get a small amount of smoke from exhaust, but today it was clouds and clouds of white smoke, to the point I had to pull of the road as it was dangerous for other road users. I revved it whilst stationary for a couple of minutes, and it cleared, so I set off again. Got about 5/6 miles, and temp. gauge went off the scale, as far past 'H' as it can get, and water pi55ing out from expansion bottle. I pulled over immediately, and switched the engine off. I was parked at the entrance to a disused airfield, on a bit of a blind bend, so after 10 mins I had to risk starting the engine and limping her up the road a bit, but she didn't start
The engine sounded like it wanted to turn over, but then just 'knocked' and sounded jammed / seized. I didn't dare try it again.
I've had the AA recover it to home, shoehorned all my tools into my wifes car, and went to work. I'm just after advice as to best course of action really, I should mention I changed all the drive belts recently, and have done all the obvious maintenance, changed rad cap / therm. / coolant and burped system etc, cam belt changed 6000km ago, regular oil and filter changes. I'm worried I didn't tension water pump belt correctly and coolant wasn't circulating properly.
I would really appreciate any advice.
Many thanks.
The engine sounded like it wanted to turn over, but then just 'knocked' and sounded jammed / seized. I didn't dare try it again.I've had the AA recover it to home, shoehorned all my tools into my wifes car, and went to work. I'm just after advice as to best course of action really, I should mention I changed all the drive belts recently, and have done all the obvious maintenance, changed rad cap / therm. / coolant and burped system etc, cam belt changed 6000km ago, regular oil and filter changes. I'm worried I didn't tension water pump belt correctly and coolant wasn't circulating properly.
Many thanks.
