bought a surf 1990 import which was banging like hell, took the engine out to find the flywheel had completely torn away from its crank shaft bolts! replaced the engine(cause the fly wheel crank end was floating out way to much) to find that there is about a 5mm gap between torque converter and the fly wheel of the replaced engine??
. can I insert spacers like washers?
