Gurgling noise?
  • Gurgling noise?
    My boyfriends 2.4 auto diesel Surf, which he has had for about 3 months makes a gurgling noise, coming from somewhere under the bonnet, it has donethis ever since we had it. It was leaking (ever so slightly) coolant (We'd put about half a litre in each month), so we took it into the garage and they fitted some new clips and said that was the reason for the leak, however it still makes a gurgling noise, could this be an air bubble in the cooling system and it just needs bleeding?
    Also when we drive on the motorway the thermostat goes up close to the red but it has never hit it, a mechanic friend said this may be linked to a bubble in the coolant, as the thermostat is registering the bubble and thinking it's hotter than it is (something along those lines anyway)??? I have absolutely no idea, so would really appreciate any advice, thanks.
    try burping the system .........do a search on burping
    oh and normal procedure is to be told to put a new rad cap and thermostat on
    oh and don't try and put the surf over your shoulder is quite heavy
    this may help..........
    http://www.showmesome.info/hilux/workshop/coolant.htm
    http://www.hiluxsurf.co.uk/forums/sh...hlight=Burping
      The thermostat is reading the bubble? Sure he's a mechanic?!?!
        Well I'm not quoting him, he said something along those lines, and yes, he's an aeronautical engineer
          That's over my head them !!!!
          Hi n welcome by the way
          There's always a Payback .... Ya just never ever see it Comin !!!!
          Buncefield Burner
            Small world! Me too!
            I guess his message was lost in translation then
              Tis a very small world. And lost intranslation/ me not listening :-)
                Not too many liquid cooled aircraft engines out there.
