Hello,i recently bought a 91 Surf SSR-G.
Everything works perfect on the car exept one thing:
As i lifted the car up and had a look at the tyres and the steering i found out that, when rocking the left front tyre, the idler arm seems to be loose in his bearings...now i dont know if its a bearing, but the last joint before the attachment to the chassis seems to be wobbly...
[IMG]
[/IMG] i am concerned since im going on a trip through australia...i attached a photo so u can have a look at it....
should i change the idler arm?? is this phenomen normal??
help would be appreciated..thank u folks
manuel
manuel
