Came out to go to work this morning, and thought ' Thats a bit out of order, someone has tipped a gallon of oil under my truck' The dipstick confirmed that my initial thought was wrong !!
Nothing else could leak (or store, then leak) a gallon of oil overnight. Are you 100% sure it's engine oil? Mind the oil will never be at the top mark on the dipstick, it'll always be in between the marks. Also, are you 100% sure it was filled properly after the service?
That can't dump a gallon of engine oil when the car is stationary.
mine did.it was reasonably ok whilst driving but when i parked up it lost about 3 litres over the driveway
I've now changed the rocker gasket, and re-cleaned as much of the oil from the engine as possible, and there is still a very slight leak, but this may be attributable to whats still left from the rocker gasket. I parked the truck identically to when I had the pool of oil underneath, and only a couple of spots in the morning. I can't see any other cause at all, pipes to turbo and alternator look ok, no obvious leaks from there, and dried all around sump nut and that was still ok the following day. I am of the opinion now that oil had collected from the leak from the rocker cover, and dumped itself on the road when parked at an angle. I'll continue to monitor it and see what happens.
