Bad steering
  • Bad steering
    I have just bought my first surf and hit a curb after a couple of weeks.
    Since then I have had a few steering problems. I have had the tracking and balancing done and they were both ok. The problems are:
    Steering wheel shaking
    Pulling to the left which is worse when moving forwards slowly, and when I put it in reverse the steering turns the opposite way.
    Can anybody help or recommend a garage near chester as I am driving to France in it next week?
    Thanks
    At a gues if you have only hit a kurb i would put money on it being the traking. and get a second opinion, was the garage reputable. I had a similar problem recently and traked it up myself with a long piece of 6"x2" now it's purfect.
    Or buckled wheel or balancing all would have been picked up by a decent garage
    www.cnpbetterhomes.co.uk
      It was checked at my local ATS which are normally pretty good.
      I have read similar problems about the idler arm or bushes would these cause the same problem?
        That sounds pretty bad. Could just be a jammed brake caliper (surfs have to be kerbed pretty amazingly badly to do major damage). But a worn-out steering box could make for *similar* symptoms.
          Could do but i would have thought you would have had signs before, if you only clipped a curb can't be much, did you see them check over the surf?
            Yeah I was there whilst they done it.
            I have just been in it now and it does not pull to the side when I accellerate quickly and it is a lot worse when I reverse as the steering wheel turned a full revolution within about 10 metres??
              You've gubbed a tyre? Buckled tyres always show up as a wobble when moving slowly.
              Swap the front you kerbed with one of the rears or the spare, see what happens.
                And, in the interests of increasing my post count...
                A buckled tyre may not show when the wheels are balanced and almost never noticed when the whels are aligned.
                Balancing is done rotationally (longitudinally), buckled tyres are acting latitudinally.
                  I will give it a try.
                  Thanks for all posts
                    Just changed the front wheel and it seems to have done the trick.
                    Thanks all.
                      i would get that tyre checked over - you dont want it to blow-out at speed!
                      Landcruiser Colorado
                      Sub. Forester
