This morning I replace the injector with the ones from my old head as i know these 4 were working to see if I could get the truck to start. still the same though, will fire up on the starter motor but as soon as the starter motor is disengaged the engine dies, also smokes extremely when trying to run. Its been off the road for three weeks now and the taxi fares have used all my money as well now. Has anybody previously had this problem or any ideas what could cause it to happen?
Really bugging me now!
No havent touched them, the new head came with injectors in but wen it didnt start fort maybe they were at fault so i put my old ones in and still the sameOriginally posted by sledge View Posthave you done anything to the injectors like taken them apart to clean themSurfin on the tidal waves of mud!
Black smoke is either too much fuel or not enough air. Are the air filter, all the inlet pipework and the turbo clear?Originally posted by YoungOffroader View Postsmoke is black, timing has been checked many a time by many people now as its the first thing we all suspectDo you know that, with a 50 character limit, it's
Yer its all clear, air filter is a K&N filter on the inlet pipe and from there the air way is all clear. just spoke to a diesel mechanic n he again said timingOriginally posted by Albannach View PostBlack smoke is either too much fuel or not enough air. Are the air filter, all the inlet pipework and the turbo clear?Surfin on the tidal waves of mud!
When I think more about it, black smoke can also be poor atomisation. Poor atomisation can be due to duff injectors or an under performig pump (not enough pressure), check them next.
Timing is more likely to give you grey smoke.Do you know that, with a 50 character limit, it's
only took the pipes off the injectors and left them in there correct placesOriginally posted by Albannach View PostIf you had the injector pipes off the pump too, did you reconnect them properly? It's possible to connect them up wrong.
Looking from the back of the pump:
3 1
4 2Surfin on the tidal waves of mud!
