Really bugging me now!
  • Really bugging me now!
    This morning I replace the injector with the ones from my old head as i know these 4 were working to see if I could get the truck to start. still the same though, will fire up on the starter motor but as soon as the starter motor is disengaged the engine dies, also smokes extremely when trying to run. Its been off the road for three weeks now and the taxi fares have used all my money as well now. Has anybody previously had this problem or any ideas what could cause it to happen?
    Surfin on the tidal waves of mud!
    have you bleed the injectors and pipes of air?
    have you primed the fuel filter?
      yer all primed n plenty of fuel came out wen i cracked of the injectors and turned it over.
        have you done anything to the injectors like taken them apart to clean them
          No havent touched them, the new head came with injectors in but wen it didnt start fort maybe they were at fault so i put my old ones in and still the same
            What colour is the smoke?
            Is the timing right?
              smoke is black, timing has been checked many a time by many people now as its the first thing we all suspect
                Black smoke is either too much fuel or not enough air. Are the air filter, all the inlet pipework and the turbo clear?
                  Yer its all clear, air filter is a K&N filter on the inlet pipe and from there the air way is all clear. just spoke to a diesel mechanic n he again said timing
                    When I think more about it, black smoke can also be poor atomisation. Poor atomisation can be due to duff injectors or an under performig pump (not enough pressure), check them next.
                    Timing is more likely to give you grey smoke.
                      If you had the injector pipes off the pump too, did you reconnect them properly? It's possible to connect them up wrong.
                      Looking from the back of the pump:
                      3 1
                      4 2
                        3 1
                        4 2
                        only took the pipes off the injectors and left them in there correct places
