Hi
Anybody know if it is a filter or a 1 way valve. Located near Fuel Tank there are 2 Fuel lines that go towards the Engine and 1 from the top of Fuel Tank / Sender this is the one fitted with the Filter / Vave that goes over the top of the Fuel Tank and up to the Filler? It has a fitting direction arrow on it from the Tank towards the Filler and when removed there is NO Fuel in it which makes me think that it is a one way Valve but when you blow through it either way it will not shut off. Could this cause any problems ?
