Just replaced crank pulley ($168nzd from ToyotaNZ), fairly easy job, about two hours. Removing the rad did make a difference, a bit more room to get at the pulley. Was gonna try the ignition trick to loosen the bolt but i gave it one more brute strength try with a longer bar and managed to get it loose.
I must say a big thanks to this site and all contributors for all the wisdom recieved, its been a huge help.
I just need to know do i need keep an eye on it as it gets "run in" or will be fine as long as it was torqued up properly?
Im assuming it will be ok but I dont want it to come while driving.
