This one's got me stumped.
I've been preparing the mrs motor for MOT & found a fuel pump leak. I've pressure washed the engine (to look for the leak) and the leak misteriously stopped.
Today we have been out and the throttle is behaving a bit weard.
It started by the idle speed dropping to 500rpm, then when we came from Asda the revs refused to drop below 1100 rpm. I've just been out now and the revs suddenly refused to respond, could get max 1500rpm on full throttle (about 15mph on the road)
I stopped and removed the TPS sensor cable sprayed it with WD and refit it, no differance, stopped again and removed the ECD fuse, left it out about 2-3 mins, re-fit it and it was off, full power and everything.
This worked until I had to stop, once it went back to idle it would not rev again.
Sometimes it just picks back up and will rev normally, sometime I cannot get it to rev up again.
There is no fault code displayed.
I'm thinking throttle position sensor fault. any thoughts
