http://www.toyotasurf.asn.au/techsite/glowplugs.htm
the diagram at the bottom of the page, the three bit's at the top, and the 2 at the bottom on the dotted line, need to all go together right to insulate the bar from the block, if they're in the wrong order the bar makes contact with metal and when it's powered up it shorts back to the block blowing the fuse.
