hi all.
I've got a 1st gen 2.4 td manual surf but recently it has started shaking when i am going along. I've had a look and the rear lower Universal Joint (U.J) has busted on the prop shaft, i know i can buy a new U.J but i also need a lower U.J casing as mine is now cracked. does anybody know if i can get that part on its own or do i need a whole new prop shaft and how much should a 2nd hand complete prop be roughly?
many thanks
Will
many thanks
Will
