I had problem with strange noises on my 2.4 earlier this year. Turned out to be the dual mass flywheel breaking up and bits of it getting bounced about the bell housing every so often.
Weird Rattle
I have had the exact same problem, it sounds just like gravel hitting the underside of a thin metal plate, mine also turned out to be the Flywheel, just got myself a new one with new bolts and a clutch kit but its cold outside so i am going to live with it for a while, anyone ever fitted a flywheel on a surf, are thay hard to do, i can only imagine its a case of dropping the prop and gearbox and then replace the clutch and flywheel, if they don't fall out on there own soonOriginally posted by RichieLI had problem with strange noises on my 2.4 earlier this year. Turned out to be the dual mass flywheel breaking up and bits of it getting bounced about the bell housing every so often.
Roy
When ya stop having fun, Ya start getting old
flywheel job.
I just had it done. Broken pieces and bolts from flywheel really polished bell housing while trashing inside. It created a havoc with clutch assambly as well. Both parts had to be replaced to the tune of 1600 clams. Runs like charm now.
I drove by a gerrage today and said its that for sure.gettingitdone this week and no more driving till its done.Originally posted by TadpoleI just had it done. Broken pieces and bolts from flywheel really polished bell housing while trashing inside. It created a havoc with clutch assambly as well. Both parts had to be replaced to the tune of 1600 clams. Runs like charm now.
