Originally posted by Antshiel
help
My tuppence worth, the t055er5 didn't fit the Glow plugs properly & blew the 80 amp fuse .....Originally posted by plumb bobIf relay is clicking but no power, then I'm pretty sure it's the fuse, as the relay only switches power to/via the main 80 amp fuse.
Good Luck
There's always aPayback .... Ya just never see it Comin !!!!Buncefield Burner
Yep, my thoughts exactly. That's one of the catalogue of things that was wrong with my Surf when I bought it. They'd even tried to bend the pins of the blown fuse together!Originally posted by SurferjessMy tuppence worth, the t055er5 didn't fit the Glow plugs properly & blew the 80 amp fuse .....
The bus bar for the glow plugs should be insulated from the engine with 2 insulators, should be stacked thus: Blue insulator, Bus Bar, Wire from relay, black insulator then the securing nut.
And they should never replace only one glow plug.Do you know that, with a 50 character limit, it's
If the turbo light doesn't work when you're driving, the vacuum hoses are possibly on wrong.Originally posted by caneyhi all, it gets worse got dash lights now blown fuse, green turbo light on with ignition but dont work when driving, they can re do glow plugs not overjoyed with that. ta all,
Check here for a pic of how they should look
http://www.hiluxsurf.co.uk/forums/sh...ht=turbo+lightDo you know that, with a 50 character limit, it's
It sounds like this garage is grabbing at straws, as they don't know how to fix it, and are obviously ot expierienced with these vehicles or diesels in general.
I would discuss with them the option/possibility of having it repaied by a diesel specialist at their expense.Rob
Still working for the man!
brill chaps garage had put pipes to turbo pressure swith on wrong, swopped round as per pic turbo boost and green light, got dash lights working, blown fuse, but, when lights are switched on me clock and radio go out, you coudant make it up coud you, still less for the bril mechanic monday, cheers
So it looks like they were monkeying around with a bit more than just the glow plugs then, sounds like they were just pulling stuff apart willy nilly in the vain hope of stumbling across the fault by accident, at your expense!
Unfortunately there are still a lot of garages out there without the skilled staff to do the job they profess to be able to do!..
Downlod the 3rd from the bottom, put it on a disc and give it to them, at least thay will then have as much tech info as the toyota technicians. ( if they can read that is)
ftp://ftp.bauchan.org/Toyota/repair_manuals/Last edited by plumb bob; 24 November 2007, 17:37.Rob
disco now gone aswell
