Hi all
I need some help as usual!! My 2.4 TD surf decided not to start this morning I have tried jump starting but makes no difference it just click once. I have checked all earthing and all looks ok. When connecting a meter the battery voltage drops down to about 10v when trying to start so again this looks ok. So I think I am left with a starter motor problem, what do you think? is my observation skills ok. If so I need a bit of advice on how to get the starter motor out I have read it is a nightmare!! Do I need to remove the wheel I have read that you do on the 3.0 but not sure on the 2.4, what other bits do I need to remove to get it out?
Once out shall I replace the whole thing from rough trax or try cleaning the contacts or replacing the contacts?
Anyway thanks for your help I have been cheered up no end by reading all the posts about bruised and battered hands trying to get this out LOL
Nick
Nick
Lots of blowing fuses points to a knackered regulator, although if it only happens once, could be a momentary short circuit somewhere (I've had a fuse blow on an older car when insects got into a circuit board!).
