So I changed one of the upper ball joints today and took a few photos of the work.
I started by taking off these nuts
Then I pulled this pin with a pliers and removed the nut with a $$$$py vicegrip. Get a 24mm closed spanner to do it cos the vicegrip was a last resort. Next week for the other side ill have a 24mm and a 22mm spanner. The 22mm is for the new one that has a smaller nut.
I couldnt get the ball joint out after i used the splitter tool cos there wasnt enough room so I put something in this space and it gave me moor room when I let the jack down and the lower nut nested on the brick.
You can see in the above picture where I put that tool to give me more room to get the ball joint out and the new one in. It kept that part (i dont know the name of it but the part with the 4 holes for the bolts) from dropping so much and I had more space, I only needed a few more cm.
I had to guide everything together as I lowered the surf and it all went together good
This is it finished
The hardest part of the whole job was removing the big nut because I didnt have the wright tool. I had to use a vicegrip which is a bad idea but it worked with a lot of effort
Sure Ill put in a photo of the great surf itself with new tires too. What do you think?
This is it finished
