I'm trying to take the crankshaft pulley off, but I can't find the bell housing inspection plate. Where is it?
I had a good search around and found some good tips for removing it:
http://www.hiluxsurf.co.uk/forums/sh...eel+inspection
My surf is in too many bits to turn over
I like, but what is it that holds the flywheel in place?
I'd like to try and jam the starter ring gear teeth...
This is what happens when you give an idiot a Haynes Manual...
Thanks.
Thanks.
