Crankshaft Pulley
  • Crankshaft Pulley
    I'm trying to take the crankshaft pulley off, but I can't find the bell housing inspection plate. Where is it?
    I had a good search around and found some good tips for removing it:
    http://www.hiluxsurf.co.uk/forums/sh...eel+inspection
    My surf is in too many bits to turn over
    I like, but what is it that holds the flywheel in place?
    I'd like to try and jam the starter ring gear teeth...
    This is what happens when you give an idiot a Haynes Manual...
    Thanks.
    Surfin' Swiss Style...
    With the front two pulleys removed from the main pulley, you'll see some cut outs in the hub, get a long prybar, about 18", and wedge the end in these notches, then rest it on the steering box. This will lock the crank to let you remove the nut.
      Thanks TonyN. Good man yourself.
