I have replaced the fuel filter housing with brand new - still the same problem.
However, I have noticed something.
Picture this.
I am slowing down as I approach lights and as is often the case I notice the revs (very quickly) flicker down to just above 500 and come back up to normal. So I slow down further and I get to the lights and stop, the engine then cuts out as I do..... This is what happenes to me normally.
However, sometimes if I am at the lights and quickly put the gearbox into neutral, before it cuts out (has to be well timed) the car will happily sit there and idle until the lights go onto green, where I put it into drive and away I go - again having to floor it before the engine cuts out altogether.
This isn't always possible as sometimes the car doesn't wait for me to stop before it cuts out. I can be slowing down for lights or a roundabout and I get down to 10 / 5 mph the engine cuts out then leaving me no opportunity to put it into neutral.
I am thinking of putting jubilee clips on all my fuel lines as I think the old rubber pipes might be getting hard and letting air in (the regular clips aren't tight enough anymore....?)
What do you think?
Picture this.
What do you think?
