Hi all, I need some help with my 1992 2.4 EFI TD Surf
History so Far> Had for 6 months, Problems from the start with the check light coming on on hills or under load code 12
Checked all vac hoses, connections, tried backing off fuel cap, run redex all the time in tank (diesel only) new air, fuel filters, new filter housing (primer pump) tried the screw adjustment on injection pump, all to no result!!!
Have just completed a 8 hour job changing the injecter pump for a recon unit
started fine, seem good to pull away, got up to 70
on duel carrageway going well then the check light came on again, done the test across the terminals and got code 12 coming up again AHHHHHHHHHH
Has anyone got any more ideas PLEASE!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
on duel carrageway going well then the check light came on again, done the test across the terminals and got code 12 coming up again AHHHHHHHHHHHas anyone got any more ideas PLEASE!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
