posting this here as half the question involves the engine....
can you stall test our surfs???
by stall test i mean on some of the plant kit i encounter you can do a test that diagnoses whethere the engine or the transmission is kerputt depending on where the revs stop/max out.
the problem is my surf seems really sluggish, not done no major work to it that would involve extra weight or anything, i am running 15" 10.5 bfg ats all round with good tread and 32 psi on road... the tranny oil was completley changed in april - dont ask!!!
would changing/overhauling the injectors work i am thinking of dropping the oil in the next couple weeks it was last done in march, so 6 months...
any advice greatly appreciated
thanks in advance
graham
thanks in advance
graham
