I have noticed that the water in the expansion bottle has a slight film of oil on it. 1990 2LT-E. Engine starts and runs perfectly, and doesn't use oil or water. Any suggestion as to cause, and any repairs, appreciated.
Oily water??
Originally posted by mark g8awoyou have two possibilities
one being contamination when you fill the water up
the other being possible breakdown in the head gasket
i could be wrong though.........
Have you flushed the coolant out yourself or just topped up the existing stuff.
Is the film colourless?????Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
oops
black sludge sounds like head gasket to me m8 id dran and flush it all out refill with fresh from a clean source and see if it returns if it does get the head tested for possible gasket m8black n tan
black n tan
yes i am a dobermann man
Was it flushed or just drained? i flushed mine out for 1/2 hour with hose.Originally posted by Muzz67Cooling system was flushed at local garage 4 weeks back, oily film is better described as black sludge.
Lots of gunge came out it was like mud!(\__/)
