Hi all, I'm running a '92 2.4SSR-X with a 2LTE engine. Have recently gone through the usual cylinder head trauma (new head, bolts and quality gasket), HOWEVER it seems to be running hotter than it should do. The gauge goes up to just below the middle quite quickly, the (new) stat seems to be opening, the viscous fan is good and the heater works. The thing smells hot, after a ten minute drive the engine, especially the turbo is still hot for an hour or so!!!! It still starts and drives spot on, doesn't use any water etc.
Is there a bleed plug anywhere that I have missed????
Thanks in anticipation!!!
Dave.
Dave.
