Hi All,
its a bit hard to explain what I am after but i'll give it a go....
A little while I tried to put on the aircon belt but in the middle of the job had to go and one of my helpful family members tried to put it together (without the belt)...anyhow it seems that they did not bolt the crank tensioner wheel (i think thats what it is) and it came loose (I found it on the mesh)...anyhow...the little bolt that goes between the wheel and the actual case is missing and I havent the faintest idea of what its called and how to obtain it....without it the wheel seems to rub against the wall and thats obviously a problem...
the wheel i am talking about is the one looking at front of engine is on the bottom left hand side and about 9cm in diamater...sits on the tensioer bolt which sticks out...
hopefully someone knows what i'm talking about
