Right i have done all the correct things used the search button and found some promising and interesting info, BUT i have a problem.
Most of the time my truck runs fine no smoke (apart from start up and when cold) and seems to go fine, is slow but to be expected. My issue is sometimes when i change into 3rd the trubo does not kick in i can hear it spinning up but nothing, it get a bit embarrsing, and occasionally when this happens it smokes. I think this is cos of the extra diesel it pumps in thinking the turbo is gonna help make use of it, is getting chucked into the exhaust.
This does not happen all the time. I though it was the vac pipes not being connected so found the diagrams on here and had a look. i will post a pic to show which one is off (the one i am holding not sure of pic quality). It has been deliberatly removed and had a screw put in to to block it off! So removed screw and reattached and started up and it cuts out. there is a valve thing (sorry not more specific) that snaps shut when it cuts out. any ideas why this should happen and weather these things are connected! I know danno put a new turbo on it when he had her.
any help much appreciated
