Well the engine swap is complete hooked the batteries up , turned her over to get oil pressure up, drank half a gallon of diesel getting fuel up to filter (does not like pumping it uphill, truck still on stands) fire her up and......................... oil leaking out of oil cooler manifold on side of block!!!
The annoying thing is i removed this while engine was out to replace gasket and found it was set like concrete, tried the one on the other block to see how easy gasket was to get off and it was a nightmare...........so thinking the easiest way was to replace with existing gasket and a thin layer of gasket cement, big mistake! So now i have got to struggle to remove it in situ and replace the gasket anyway.... B###er, still at least it runs well with no knocks.... The saga continues !!!
