alternative exhausts?
    If you have a two inch body lift you can fit 265/75r16 provided you use the shogun wheels etc! they come in at about 31.8 inches tall! wont stick out much on a narrow body surf n should fill the arches very well mate!!
      cool great info, computer disconnecting me after 2 mins, so better keep it short. SOOOOO it's 2 inch body lift, standard height improved springs from Milner, and 265/75/16s.....or does anyone else have any other budget ish tips....I do have this set of standard 15 inch alloys....
      cheers
      dinna say eh?....say fit?
        cheers
        You could always ask tonyN if he has any used tyres around but you will be pushing it getting anything bigger then a 31x10.50r15 on a standard rim!
        To get back costs you could always ebay your standard surf rims! Check out my surf in the " ok! a few pics" thread under general! Thats what 265/75r16's look like!
          cheers guys, got a suitable looking centre box from a transit, £34 brand new, will have to magic up some sort of bend to make it a side exit in front of the rear wheels,but it's looking good. Thanks again for the info on tyres and lifts...these wellers of the shogun someone said "the off set is different" what does thst mean?
            the offset is the difference between the mounting face of the wheel and one of the edges or something along them lines someone will explain it better, but it basically means the wheels will sit closer to the body / further away because of the offsets being different. I think shogun wheels will sit further away so stick out from the arches a bit more.
            =SOLD UP!=
              ahhh, these wellers were in the s$$$$py on a mk1 shogun, 5 for £20 with 3 legal ish tyres so I'll have to tread carefully since I dont have the plastic arch extentions 265/75/16s seem to be the biggest recommended.
              What about insurance for a 2 inch lift anyone got any companies they'd recommend???
                i'm with Adrian Flux, there's quite a few on here with lifesure i think.
                I'm sure someone who knows for sure about the shogun wheels will be able to give you a more definate yes/no as to whether they would be ok, but i'd say stick em on and see how they look with whatever tyres they got on at the moment.
                =SOLD UP!=
                  Basically the larger the offset the more the wheel will stick out! standard surf alloys are -8, so -20 is a larger offset then -8 ( I THINK!!)
                  • #24
                    with 265's and a larger offset you still shouldn't have any real problems with not having wheelarches!
                    • #25
                      Landcruisers have the larger off-set alloys.
                      • #26
                        exhausts
                        Exhaust gone from front pipe back. Heard transit rear section good swap...Anyone got more info...Thanks
                        Hi,
                        I purchased a S/S Powerflow tail-pipe and a S/S 3 ft. straight section on ebay. I then took the mid-section flange off the old exhaust and basically wired it all in place. A sat. morning visit to the local welding garage for the welds and all for round about £100. The 4.5 inch tail-pipe makes it rumble like a V8. The exhaust was from a Golf.
                        Cheers,
                        Chris
                        Powered by Toyota!
                        • #27
                          any pics?
                          Tim
                          • #28
                            Originally posted by dirtydog
                            any pics?
                            I`ll take some tomorrow. cheers,
                            Powered by Toyota!
                            • #29
                              Alternative exhaust £100 all in.
                              Hi folks,
                              Took pics today, truck been working hard this week. As you can see in the pics- a coating of grit-salt collected from the hillies of east lancashire!
                              May fail MoT as tail-pipe does not quite extend beyond the bumper. You will see in one pic the flange from the old exhaust welded to the 3mm stainless tube to make the coupling.
                              Any questions please shoot.
                              cheers,
                              Powered by Toyota!
                              • #30
                                That tailpipe is fine, it'll pass the MOT.
