Some time ago I replaced the transmission on my ssrx. Now the 4 wheel drive does not work. There seems to be some sort of a shortas while normal driving the 4 wheel light flashes, and the relay clicks but no 4 wheel engagement. We have lifted ot off the ground and rigged some sort of relay system and the gears engage. Could it be the computer located under the radio that is causing all the trouble?
4 wheel drive
Originally posted by Cash4Some time ago I replaced the transmission on my ssrx. Now the 4 wheel drive does not work. There seems to be some sort of a shortas while normal driving the 4 wheel light flashes, and the relay clicks but no 4 wheel engagement. We have lifted ot off the ground and rigged some sort of relay system and the gears engage. Could it be the computer located under the radio that is causing all the trouble?
4 wheel
Stormforce, thanks for the quick reply. The mechanic said all was well with the vac lines. Prior to the change, whenever I pressed the 4 wheel button on the gearstick, I could actuall hear something engaging below the truck, now I get nothing, no relay click, nothing!
Originally posted by Cash4Stormforce, thanks for the quick reply. The mechanic said all was well with the vac lines. Prior to the change, whenever I pressed the 4 wheel button on the gearstick, I could actuall hear something engaging below the truck, now I get nothing, no relay click, nothing!https://www.facebook.com/groups/henpals/
