Hi All,
Sorry for the newbie posts...
I'm probably showing my inexperience/newbiness but when I turn the ignition to 2nd position (all lights light up)...i can't seem to see the glow plug light
...is it the engine light? I do hear the continuous alarm/buzzer after 5s (very annoying) then a clunk/click so i gather thats the glow plugs right?? and then i turn her...sometimes it starts on first go but from cold but takes normally 2 goes (the car is stood at least 24 hours between starts as I don't user her for commuting)..then there is a fair bit of smoke which i gather is cold engine which clears up completely during the drive (no smoke even when i accelerate after the engine warmed up).
I also have the issue of lights for the heater panel and the auto box panel (to see which gear i'm in)...they seem not to be there/don't work...are these just simple light replacements? If so..can someone point me to how to replace them?
Other issues I have are which I would very much appreciate your help on
- back windows goes up but not down from the key which means i need to open window from inside to open back door (searched forums and typically its the other way around..i'll investigate for corrosion but any other pointers?)
- electric mirrors don't work (i guess this could be cabling..need to take the console off..does anyone have any guides on that)
- not sure if the suspension switch is working..how can one tell?
- the sunroof motor is working but window not moving...does it have a chain/link system or is it more difficult?
- i'm about to service her (fuel, oil, air) but can't seem to find info on how to drain the auto box oil...plenty of posts on how to fill her through the dipstick but not on how to drain/change filter
Well...all in all she's a great vehicle and am planning to join the thames valley 4x4 for a run in february to see how she goes...thanks for all your help so far!!!
...is it the engine light? I do hear the continuous alarm/buzzer after 5s (very annoying) then a clunk/click so i gather thats the glow plugs right?? and then i turn her...sometimes it starts on first go but from cold but takes normally 2 goes (the car is stood at least 24 hours between starts as I don't user her for commuting)..then there is a fair bit of smoke which i gather is cold engine which clears up completely during the drive (no smoke even when i accelerate after the engine warmed up).I also have the issue of lights for the heater panel and the auto box panel (to see which gear i'm in)...they seem not to be there/don't work...are these just simple light replacements? If so..can someone point me to how to replace them?
:- back windows goes up but not down from the key which means i need to open window from inside to open back door (searched forums and typically its the other way around..i'll investigate for corrosion but any other pointers?)
