Hi All...
ive had an intermitant engine light recently...and think ive figured out whats going on..
the diags on the engine light were pointing towards turbo sensor...so just to see what happens if i run with the turbo vacuum pipe off after a short drive...i lifted the bonnet to fit the hose back on again...and noticed oil comin out of the filter where i removed the vacuum hose..
i then removed the hose from the sensor on the airbox..and blew thru it..again oil in it...
stupid question...is it a big problem to repair?...whats the cure?
thanks guys...
S
thanks guys...
S
