hi the turbo lights on my surf has got my head done in 1s what they for and 2nd my red 1 comes on gos out then they both come on then red comes on again for a bit then off then the green 1 comes on any hellp could this just be a bad connection
The green one should come on when the turbo is boosting, usually about 1800 - 2000 rpm and go out when not. the red one is the engine management light and should only come on when you have a problem with engine. Have a look at the bottom of this page. Do a search on engine management light.
hi thanks for the help its just when it does come on there no change at all still go's like a train and sweet as a nut
Doesn't mean that everything is going as it should. mine was going fine for about 3 weeks after i bought it and BOOM the head cracked. This was due to the t*at i bought it off removing the stat. innevitabely (think thats how its spelt) engine overheated and head popped. warning lights are there for a reason, ignoring them could cost you dearly.
ok just had a look all the vacuum pipes are ok and so is the cooling and just email the lad that had it before me and he say that they started to do it when he put the new cd player in as well as all the other dash lights doing as they please but as i said its not all the time put the key in all the lights come on and stay on could he have done somethink when he put the cd in any hellp plz
Hi David, I'm no auto electricle expert but if it started playing up when this guy fitted a CD player it's possible he's connected summat up wrong, i assume the player is fitted in the center dash (with the radio), I'd start by removeing the dash center and dissconecting the player, check the wireing is not damaged and see if this cures your mad dash light's, then take it from there, do a search for dash removal, its not as bad as it looks! ian
