Head Gone
    dont just sit there call an admin
    we have ramblers on here
    will be bobble hats in the shop next
    (thats as close as i could find)
    [url="http://www.frappr.com/smurfowners"]Surf MAp[/url]
      there is however an upside
      needed to change the glowplugs for a while
      should be a doddle now
        update
        head out
        no 1 looks fine
        no 2 wet
        no 3 duck pond!!!!!!
        No 4 fine
        turning the engine by hand by the front pulley wassit could hear the water sloshing about
        the only good thing is that i'm very sure it was never running or turned over
        with the water in the piston
        does anyone know of a better way of getting that pulley off other than putting a spanner on a bar jamming it on the frame and turning the key???
        so anyways got head off (bolts around 2 and 3 have at some point been very hot)
        looking fine few cracks but none of them major (beetween cylinders or water jacket)
        will know more when i get it tested
        list of things i need (may as well do now i have it in bits)
        cam belt
        cam belt tensner
        cam idler
        new fan
        glow pugs
        injectors
        fuel filter housing (needed a new one anyways)
        turbo maybe (waiting on Doc Anglegrinder to get in touch)
        up section on exhaust
        gaskets
        head
        want to have a look at the steering now i can get to it
        so maybe a steering stable thingy
        light bulb for gearstick
        oil cooler
        list goes on if you can think of anything else i could do while i have the top off let me know if i go ahead with the head i want to make the truck as good as possible
        truck looks super size now the front is lifted slightly due to the engine weighing less
        also getting a cold so please forgive the spelling as i have run outa energy
          Stretch bolts ?
            i hate to add to the list, but you will need new bolts for the head too...
            (edit, ok i was slower, but it had added sympathy...)
            it's in me shed, mate.
              New water pump whilst you're at it. Plus rad cap and thermostat, obviously.
                yup but i thought you got them with a head from Stevo
                may be wrong
                kinda looking for someone to talk me into a V8
                but as this is the first ingine i have ever taken apart
                (under very close supervision)
                i kinda loving the learning curve
                oh and people that want to ban bull bars cos they are not needed inb this country, try telling that to my mechanical supervisor on this rebuild
                4inch lifted surf 5.2 foot grease monkey. Top of the rad comes up to his collar so he has to use it as a ladder
                  Shopping Basket
                  Product Price
                  Oil Filter £6.50
                  Fuel Filter £6.50
                  Cam belt tensioner 2.4 £35.00
                  Cam tensioner spring 2.4 £1.40
                  Idler Pulley/Gear Toothed. £68.00
                  Glow Plug £40.00
                  Cylinder Head £630.00
                  Head Gasket £36.00
                  Timing/Cam cover gasket £12.00
                  Head set £31.99
                  Head bolts £22.00
                  Rocker cover gasket £8.50
                  Fuel filter head £62.00
                  Front Downpipe Auto £69.95
                  Water Pump £40.00
                  Exhaust manifold to head gasket 2.4 £5.50
                  Subtotal (Excluding VAT): £1075.34
                  VAT: £188.18
                  Subtotal (Including VAT): £ 1263.52
                  plus if the turbo is up the swanny that will be way way way to much ready folding
                  • #24
                    Get this for £400 to get you started.......
                    http://cgi.ebay.co.uk/New-Oldsmobile...QQcmdZViewItem
                    • #25
                      oooooh!!!
                      but where would you start gearbox wise???
