2.4TD Oil leak
  • 2.4TD Oil leak
    Hi all,
    First post hurrah! I've just bought myself a '90 2.4TD with a few problems! First of which appear to be a pretty serious oil leak. It's coming from behind the oil filter housing. So i have a few questions if i may.
    1.) The leak appears to be coming from between the block and the housing itself. Is it possible its a busted gasket?
    2.) Is it possible to remove the filter housing with the engine in situ?
    Thanks Guys!
    Welcome to the SURF RESIDENCE. Oil filter may not have been fitted properly so check its been tightened up 1st.
      There's a small 'trap door' panel in the off side wheel arch - 4 bolts to take it off.
      Then getting the filter out is easy.
      http://www.toyotasurf.asn.au/techsite/oilrenew.htm
      If you're lucky its just a damaged oil filter gasket.
        Hi guys,
        thanks for the replies, I've done the trap door thingy, the filter is tight, the leak is coming from between the block and the housing for definate though
          Originally posted by nutter
          Hi guys,
          That would be the oil cooler gasket is leaking then. Toyota dealer part I'm affraid.
            I figured as much. Can it be done without the engine being removed?
              Yes, just a bit fiddley.
                Theres a surprise (sorry.. owning an MR2 has made me a bitter home mechanic). Anyone got a part number for this gasket?
                Thanks Bushwhacker!
                  Just go it to Toyota with your chassis and model number (the two long ones on the data plate) and they'll have no excuse not to be able to get it for you.
                  Change the two gaskets on the oil cooler behind the cover while you've got it off, they crack now and again getting you milkshake for coolant and oil.
                    cool thanks, What type are these gaskets? metal or rubber? It's just i think i may have to tear the engine down shortly as i have a rattle that sounds worringly like big ends, i was thinking i could bodge the gasket with some instant stuff for now until i drop the lump out for a full rebuild? Any thoughts guys?
