My son changed his speedo dial face at the weekend and after reassembling it all the timing belt warning light was on.We have assumed that he has just knocked off a connector or not pushed a plug home properly?
Is this warning light just associated with the odometer and there is a process of resetting it when belt is changed? The sticker in the truck says belt was changed at 85000 miles nearly 3 years ago but I an sure it should be Km as it has only done 130000km.
Or is it more sophisticated? If it is aconnection problem with a plug then maybe we need to go back in (pain) in case another warnig my have been adversely affected.
