ferrets truck has sprung a leak! theres er.. diesel dripping off(at a fair rate.) running past the earth clamp, passenger side. the whole side of the engine is wet, apart from round the thermostat housing. i cant see anything apart from that on that side with er... diesel in it... it only does it while the engine is running. could it be the fuel pump? any ideas? all the hoses are good, there's no pin holes i can find. is there anything behind the injector pump that could leak? its been find since the rebuild up till last week when this started. HELP!
do you see what i did there? smooooth...
