Recently discovered after a question from another Aussie member about a switch on the manual box that there is a 5th gear switch. This is located forward of the reverse switch and on the drivers side. Did some tests to determine what this switch does and how it works. Only worked out so far that it operates when in fifth gear. My question is does anyone know where the wiring for this goes and why. Does it control something in the ECU, Fuel Pump or somewhere else. One suggestion is it is for economy mode but how does it work ????
Nev
Nev
but just to let you know we're still here and as baffled as you are.
Any other details or pics of the switch? No idea, but just blo*dy
