Hi, I have 2.4 Jreg Surf.
I have an oil leak from the 'oil filter housing'. Mechanic tried to get a gasket for it, no joy, so in the meantime used a seal stop, which seemed to help. Coincidently, when the leak stopped, I had oil dumped in my expansion bottle and radiator. Called mechanic, and I asked if there was any way that the leak could have found a new release into the water system internally. He said he didn't think so, and he thought the oil in rad was residue from matrix after the last time the head went on me. I had replacement head and new radiator fitted 3mths ago. He thought it was residue as there was no sign of oil level dropping. On friday we did a speed flush, on saturday I went to a dog show, which was a three hour journey there. All levels had been fine before leavin in morning. Before coming home, checked water and found a load of oil back in expansion bottle and rad. Checked oil level and was dry. Luckily had oil with me, topped up and took a litre to bring level to normal. Drove home carefully, but Surf drove well. Checked oil when got home and oil level was normal. Why use up a litre to get there but nothing coming home?
Called mechanic last night, said not a problem with the head, it's to do with the housing. He had spoken to an engineer who said yes it was possible for the oil to leak internally into the water system. So he's now going to strip the housing down, but we need a new gasket....any ideas where we can get hold of one?
Any thoughts/advice/help would be much appreciated!
Thanks!
Thanks!
