does any one know
  • does any one know
    my surf has started dripping from the small rad.surf has been standing for a week , and noticed the wet area this morning for the first time .. any one got any idea,s
    nick 1 step in front of you
    when you say its been standing for a week, did you use it after a week then notice it or as it not been used at all for a week??
    is it water/coolant or oil???
    CHEERS JOHN................
      Condensate from the air con?
        thats wot i was coming to you beat me to it......
          that is what i thought . been standing ,not used for a week . aircon dont work any way .. have 5 windows to let hot air out
          it is just water .
            it is just water .
            water or water/coolant mix???
              just water i think
                just water i think
                first thing i would look at is your water/coolant levels are ok!!
                and also if you have a good enough water coolant mixture..
                because if its just water the only thing i can think of is air con-condensation but you have eliminated that, so it must be coolant/water
                can you see it dripping down when you get on ya back???? or is it just a small patch on the floor???
                does it look brownish in colour?? or does it smell horrid ? if you can smell it that is? just trying to think of as many things as poss....
                  just been on my back . not drippin any more .rad stil wet , has staines drive so not just water i guess
                    keep an eye on it then mate and try and track it to its original source and keep an eye on your levels. be a good idea to keep some coolant mix on board just in case..
                    try topping it up before you first use it and see how much it takes..
                      just run it header tank low.filled up .comeing from rad it seems ,does that mean rad.or will radweld do
                      strange how it went while not in use
