my surf has started dripping from the small rad.surf has been standing for a week , and noticed the wet area this morning for the first time .. any one got any idea,s
does any one know
when you say its been standing for a week, did you use it after a week then notice it or as it not been used at all for a week??Originally posted by koedmy surf has started dripping from the small rad.surf has been standing for a week , and noticed the wet area this morning for the first time .. any one got any idea,s
is it water/coolant or oil???CHEERS JOHN................
first thing i would look at is your water/coolant levels are ok!!Originally posted by koedjust water i think
and also if you have a good enough water coolant mixture..
because if its just water the only thing i can think of is air con-condensation but you have eliminated that, so it must be coolant/water
can you see it dripping down when you get on ya back???? or is it just a small patch on the floor???
does it look brownish in colour?? or does it smell horrid ? if you can smell it that is? just trying to think of as many things as poss....CHEERS JOHN................
keep an eye on it then mate and try and track it to its original source and keep an eye on your levels. be a good idea to keep some coolant mix on board just in case..Originally posted by koedjust been on my back . not drippin any more .rad stil wet , has staines drive so not just water i guess
try topping it up before you first use it and see how much it takes..CHEERS JOHN................
